LOUD Knock 01' 2200 Auto - Maintenance and Repair Forum
Sunday, September 25, 2005 4:34 PM
I recently bought a used 01' cavalier with 220 engine and autmatic transmission. After a little driving it started to have a rattling noise that would get louder as i mashed the accelerator. Today I start the car and hear a pronounced knocking at idle that grows extremely loud and irrythmic as i accelerate, the more I drove the vehicle the louder it got; the idle started stuttering and the oil light would come on at idle ( or what I now call and idle) it sounded like it was going to explode while I was on the highway to get a repair manual. It also cut off at a stop light a few times, like it was struggling to idle. The transmission feels like it's going to explode before finally shiffting in an irregular pattern.
I know you're going to say put oil it in it, duh, but the dipstick reads full, I've got it right at the max mark and it stays there, the coolant looks fine too, although it's red, but I figured it was some sort of "special" coolant that they put in cavaliers.
It sounds like I've got a rod knock, which would totally blow since I've only had this chevy for 3 weeks.
It's getting progressively worse, to the point that I don't trust it to take me to work tomorrow.
It lacks more and more power every time I drive it and the knocking/rattling imakes this pile osund like it's going to explode.
SOMEONE PLEASE point me in the right direction, cause if it's a rod I'm going to set this thing on fire.
Re: LOUD Knock 01' 2200 Auto
Friday, October 07, 2005 6:01 AM
sounds like a rod bearring problem.
Friday, October 07, 2005 7:20 AM
Sounds like time for that hi-performance re-buid !!
Friday, October 07, 2005 10:04 AM
sound like it is time to do that quad 4 swap, or3400 swap u have always wanted
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
Saturday, October 08, 2005 5:11 PM
Just a speculation -
Rods are the first to go bad whenever an engine
is low on oil....
The previous owner could have done this, then
"doped" the engine in order to sell to an unwary
buyer....
"Doping" includes some of those really thick
additives intended to stop oil burning...
One time I worked on an engine with main bearing
noise right after the new owner changed the oil ,,,,
There was sawdust that I found in the oil filter...
Nuff said....
Saturday, October 08, 2005 6:39 PM
Could be your valve hitting the piston. How it got there I dont know.
Madjack wrote:Like I said before, building an engine like ours (2.2 or 2200) is a painstaking chore , since there is so few custom made parts. It's frustrating to me too, but that's what I like about doing this engine, it's the challenge.
Monday, October 10, 2005 7:48 AM
this question isnt even related to a j-body, but a 92 chevy van. i have the same problem, the oil was burnt up by the previous owner and the engine ran with no oil. It was only driven with the loud knocking for a few miles, and it locked up once, but started again. I am wondering if just the main and rod bearings could be replaced to eliminate this knocking. I dont want to buy another engine or completely rebuild this one.
Monday, October 10, 2005 3:47 PM
lol you engine is not going to last much longer, i garentee the einge was ran at hgher speeds with little or no oil and was @!#$ up, then the owner realiozed it and toped the thing off with oil and sold it. even if im wrong you engine will not last much longer, the damage is already done and cant be reversed without major engine work.
Tuesday, October 11, 2005 12:10 AM
Off topic to Ryan Hoffman :
After pulling the pan and removing some of the rod and
main caps, a reasonable estimate can be made.
First, as to main bearings, they should NOT be galled,
especially the rearmost ones. The engine is hopeless
if the main crankshaft bearings are damaged.
If the rod journals are only slightly roughened, they may
be cleaned with mild crocus cloth using a 'shoe shine'
method to lightly polish.
Replacing the rod bearing inserts, reassembling and
testing may result in a re-usable engine. Albeit with
a limited life.
