Low trac light? - Maintenance and Repair Forum
Low trac light?
Friday, October 07, 2005 5:35 AM
Alright,
ive been having this prob for a week or two now and its starting to bither me. When Im
at low speeds, like in traffic, and go from a stop to just rolling foreward with little to no
throttle and then to a stop again when I let out onb the brake pedal and thn when I apply
it again the trac light will momentarily come on. Any Ideas? Thanks
Jon
Re: Low trac light?
Friday, October 07, 2005 5:37 AM
Is the check engine light on?
Other than that, the Traction Control uses the ABS sensors to monitor wheel rotation. Maybe one of them is bad?
Re: Low trac light?
Friday, October 07, 2005 9:06 AM
vehicle wheel sensors at each wheel need to be tested with a graphing scanner
also take a look to see if alot of metal flakes has built up on them
u can locate tham at each wheel there is a ring gear and a little sensor that sits just about the teeth on the gear it is magnetic and senses ever time a tooth passes underneath it
also check to se if there is a crack in the ring gear.
Sorry...
You have been banned from posting on this site as of 2005-09-21
00:33:32. This ban will expire 2005-09-28 00:33:32 Pacific Time.
Reason: Comments over the top regarding Jordan Kruger and other members in Versus. Also, if you have a problem with a member e-mailing you, do not bring it into the forums.
If you believe this to be in error, please contact us.
