01 2.4L coil pack and plug Question - Maintenance and Repair Forum
Friday, September 30, 2005 8:14 AM
I am just curious, I need to change plugs and I guess there are 2 coil packs in there, gm price 69.08 each so I dont plan on buying them should I be OK with just the plugs and the wire connectors or would just the plugs be ok? no problems at all just past time for plugs138,000 miles on the originals!!!! Any advise appreciated
Its all about the pain...The Jewelry and Ink are just souvinirs
Re: 01 2.4L coil pack and plug Question
Friday, September 30, 2005 8:53 AM
You should probably be fine just changing the plugs. You should only really think about changing the connectors or coil packs when you have some sort or misfire or other problem with the firing of the plugs.
