AC Pulley Noise - Maintenance and Repair Forum
AC Pulley Noise
Monday, September 26, 2005 10:00 PM
My AC Pulley is making some noise that sounds like a chain rattling. When I turn on my AC the rattle goes away.
So my questions are. Do I need to replace the entire pulley? How hard is to to replace?
Thanks,
Ryan
Re: AC Pulley Noise
Tuesday, September 27, 2005 8:12 AM
I'm not sure it's the pulley. I think it's the compressor itself. The clutch slipping on the AC compressor. Mine does the same thing.
--04 Blazing Copper Mazda 6 s
Re: AC Pulley Noise
Tuesday, September 27, 2005 11:51 AM
My g/f's 97 z24 just started it like 3 weeks ago.
http://www.ohiocichlids.com
Re: AC Pulley Noise
Wednesday, September 28, 2005 8:28 AM
You need to replace the compressor. Plan and simple. Mine was making that noise till I removed it.
Re: AC Pulley Noise
Friday, September 30, 2005 8:13 PM
Ok Thanks, any idea who much it would cost to change out the compressor????
Thanks,
Ryan
Re: AC Pulley Noise
Friday, September 30, 2005 8:19 PM
I think you can change the pulley only. By changing the compressor you will have to refill your system with refrigerant and that can cost extra $$$$. I don't know if you can remove the pulley while the comp. is in the car or not. The ones I've fixed I changed the whole compressor. None of them had refrigerant in it though.
stock '00 2200 cavy
Re: AC Pulley Noise
Sunday, October 02, 2005 8:00 AM
The problem is the bearing inside the compessor has gone bad. You will need to replace the whole compressor. DRAIN THE 134a FIRST BEFORE YOU REMOVE THE COMPRESSOR!!!
Tach Out Motorsport
Http://www.team-tachout.com/
Falmouth,VA
