2.4 Motor Mount - Maintenance and Repair Forum
2.4 Motor Mount
Sunday, August 28, 2005 11:54 AM
replacing the LD9 motor mount...
can i get some tips?
Re: 2.4 Motor Mount
Sunday, August 28, 2005 1:19 PM
there is 3 mounts , so pick 1
either way all the mounts are pretty easy
Re: 2.4 Motor Mount
Sunday, August 28, 2005 5:56 PM
ok, so the upper was eaiser than i thought it'd be.
turns out that the upper wasn't in too bad of shape, but we replaced it anyways.
next i have to attempt to fix the dog bone mount. when we took the bolt closest to the bumper out it moved back and forth with ease. is this normal?
Re: 2.4 Motor Mount
Sunday, August 28, 2005 11:28 PM
our motors rock alot with stock mounts
getting the upper insert , and the lower mount from the aftermarket is a good way to keep the rocking to a minimum , but the down side is the vibration from them
the 2.4 autos are the worse at the vibes , more so when the a/c is on
the autos idle in the 500-650 range
Re: 2.4 Motor Mount
Sunday, August 28, 2005 11:29 PM
forgot you can get the mounts from
karo@carcustoms.net , or jim@gravanatuning.com
