Is there an oil overflow thing at all? i got my oil pan gasket replaced because it was leaking and now it leaks a lot more. never heard of an oil overfill thing but maybe there is so i thought i'd just ask. when i take the dipstick out it looks overfilled.
2.340 - 60,
16.591 @ 80.52 - 1/4
Guesswho69000@hotmail.com
o yea 2001 cavalier 2200
2.340 - 60,
not that i know of........
Dillon Zellmer wrote:Is there an oil overflow thing at all? i got my oil pan gasket replaced because it was leaking and now it leaks a lot more. never heard of an oil overfill thing but maybe there is so i thought i'd just ask. when i take the dipstick out it looks overfilled.
No there isnt an oil over fill resevior. If your oil pan is leaking, Drain the oil from your car, Remove your oil pan, and oil gasket. Clean the mounting/sealing points very well.
Check gasket. Is gasket screwed up? If not you can put it back in.
Put oil pan back on, and tighten in proper sequence and torque.
If you dont know the TQ specs and Bolting sequence, Buy a Haynes manuel for your car, for all the info you will ever need.
After its all on, Check the drain plug gasket. Is it ok? If not replace, you will leak oil from there. If its good, install and put drain plug back in.
Tighten plug.
Next fill with 4 quarts of recommened oil, either synthetic or conventional, Matter not for this case.
Start car. Look under neith. Is it still leaking? From where if so?
Turn off car, rechek tq on oilpan bolts, this you have to do regardless, they loosen the first time they warm up. Retighten if neede. and you should be good to go.
http://members.rankmyride.com/djtorello
but dont ya haveta remove the engine mount to get to the bolts on the belt side of the motor?
2.340 - 60,
if you do, no big deal, the 2 tranny mounts and one engine mount will hold the engine still if the lower mount is out
You'll never touch God's hand
I've seen the ways of God
I'll take the devil any day
Hail Satan
r u sure cuz i dont want the thing fallin on me might not feel to good the guy that did it last time said they had to support it from the top but it hink he just did it because he too one of the motor mounts out. so it should be fine then if i just take it out?
2.340 - 60,
