engine is hard to start especially when hot, but never failed, just takes more time. I do engine turn up 2years before, and checked spark plug/wire set, replace IAT sensor, nothing happen. any suggestion?1999 cav2.2 thx
my old camaro used to do that. turns out it was vapor-locking
People say that what doesn't kill you in this life
will make you stronger. I'm not sure if that is true
or not, but i do know one thing-You have to learn from
it and it has to make you better.......it has to.......
vapor-locking? what does that mean?
You could have a fuel pump going out when it gets hot or you could have a leaking FPR
Vapor-Locking?????? I know Hydro-locking ,but, vapor-locking.....?
Really what you have is a common J problem. GM diside to use Saturn style starter in the J's. With age the car will take longer to start. Really threr is lettle you can do. DO NOT LAY ON THE STARTER. Unless your GM recall has been done this can start a fire.
Tach Out Motorsport
Http://www.team-tachout.com/
Falmouth,VA
