leaking anti-freeze coolant - Maintenance and Repair Forum
Sunday, August 14, 2005 12:10 PM
Hi all ... never knew I had a problem til I stopped for gas and found a puddle of coolant under the car ... opened the cap, pulled the themrostat put in about 2 litres of water in, enough to get me home without overheating ... dripping on passenger side regardless if car is running or not ... of course it drips faster if the cap is off ... when the car is not running, top looking down, the top end hoses look good, driver side even is dry, but the drip is on the passenger side (constant drip) when the car is not running ... any thoughts? Thanking all in advance ... regards ...Irv
911 ... got fire?
Re: leaking anti-freeze coolant
Sunday, August 14, 2005 5:12 PM
You need to find the leak. Jack it up and crawl underneath for a bottom-side inspection. Wear safety glasses
Monday, August 15, 2005 5:10 AM
yup instead of asking, just get under the car and look for yourself.
SO EVERYTHING!
Monday, August 15, 2005 5:23 AM
I have it jacked up ... seems a bit perplexing ... can't pinpoint it ... I thought I'd put it out there to see if anyone has had the same sort of problem (2.0l MPFI) ... here we go again
911 ... got fire?
Monday, August 22, 2005 3:02 PM
did you confirm that it's the water pump? the "weep hole" should be leaking out fluid if it is...
Monday, August 22, 2005 7:52 PM
Yeah on my 96 sc2 saturn i hit a couple of
huge pot holes by my house and the next
morning there she was dripping on my cement..
So i took it to my friends and jacked it up and
took us a while but we found the problem... it was a crack in
the radiator. $1800 later and a new radiator in
my saturn and it was good to roll. But f-that saturn
it took a @!#$ on me after fixing the radiator. So i sold it
for 500...haha. and now got a 05 chevy cavy only thing
is its auto. :0(
Monday, August 22, 2005 11:18 PM
$1800 for a radiator job???? WTF
I can find a new 1 w/ lifetime warranty for ~$100
Tuesday, August 23, 2005 1:40 AM
^ no crap. i just put a new radiator in my winter beater for $50.
SO EVERYTHING!
Tuesday, August 23, 2005 7:04 PM
yeah
i got ripped off
by goodyear, @!#$s.
Saturday, September 10, 2005 7:22 AM
it was the water pump ... what a pain in the @#$ ... changed the timing belt as well ...
911 ... got fire?
Sunday, September 11, 2005 7:31 PM
I just found a leak also. Found it comming from the weep hole on the pump, but it does not look like fun to replace. It's a '95 2.3 with 252,000 on it. Any tips here on what I'm up against?
'95 Black Z24 - Stock with airbox removed
'99 Black GTP - CTPT61 @16psi, I/C, 94 oct, W/Meth,
TC, S/kit, 3.29, Cut-out, Cat Back, Magnaflow's,
GR2's, Eibach's, GMMP FSB, FBod Brakes, Cer Pads,
SS lines, C/D Discs, 17" Comp G's
12.63@118mph on Comp TA's!
Monday, September 12, 2005 1:13 AM
My guess would be if the Rad hoses are good, I would take a look at youre water pump, And see if you have any coolant leaking out of it, If so replace youre water pump right a way.
