Starter won't crank - Maintenance and Repair Forum
Starter won't crank
Thursday, July 14, 2005 1:01 PM
The other day I whent to start the car and it cranked for half a second and then nothing. I still have power to everything else but the starter won't turn. I pulled the starter and had it tested and it is fine. I also tried jumping the car first and got nothing. These are the things I am thinking it could be:
My clutch master cylinder is leaking internaly, but still works if I pump it up = Is there a switch in there that could gone bad and is keeping power from going to the starter?
Maybe a bad connection somewhere?
Or possibly the Ignition switch is bad?
Oh, and I've got a bad oil leak, could this have contaminated something?
Any help would be much appreciated. Even though it is in kind of dissrepair it is my only mode of transportation and I just need to get it back on the road or I'm screwed.
Please HELP!!!
Car:
'95 cavalier, 2.2
___________________________________________________________
I DO NOT REGRET THE THINGS I HAVE DONE BUT THOSE I DID NOT DO
Re: Starter won't crank
Thursday, July 14, 2005 2:26 PM
yes there is a switch itc located at the top of the clutch lever. its called the clutch peddle position switch its g.m. part # is 14094368 and it costa between $8.00 - $15.00 pick it up at any g.m dealer.
good luck.
and fix that leak!
Thursday, July 14, 2005 2:30 PM
And that would keep power from going to the starter?
Thursday, July 14, 2005 4:16 PM
yes.
Tuesday, August 09, 2005 10:32 PM
Well, i replaced the switch and it didnt do the trick, ne one have other ideas?
Wednesday, August 10, 2005 7:11 AM
Have someone turn the key like they are trying to start the engine . Check the voltage on the purple wire on the solenoid , you should have 12 volts on that when they turn the ignition over to start . If no voltage is there then you may have a lose connection or a broken connection between the solenoid and the ignition switch .
You can also check to see if the starter will turn the engine over by jumping the terminals on the solenoid . Take a screw driver and place it on the terminal for your battery and alternator . Then touch the terminal that the purple wire is connected to . The solenoid should kick in and the starter should turn over . If it does'nt then you need to replace the starter or get it rebuilt .
I had a problem with my starter in which I busted the end off of the solenoid . I sent it out to be rebuild and the solenoid ran about $35.00 to have replaced . They even check the starter afterwards .
<a href="http://users.adelphia.net/~rdbryant1/index.html.html"><img src="http://registry.gmenthusiast.com/images/mrgoodwrench/personal_pic.jpg" border=4></a>
Thursday, August 11, 2005 11:50 AM
ive actually been fighting the same problem in my '99 XZ24. i started experiencing problems after changing my clutch master cylinder. i replaced the starter, and the clutch position sensor . . . and it still didnt work. i ended up wiring in an ignition start switch (provides power straight to the starter, and by passes the ignition) and ive been starting my car that way for over a year now. still cant get it to start with the key . . . im assuming my problem lies in the ignition itself. If you ever figure your prolem out, please post the solution! thanx.
