Suggestions...OIL PAN GASKET - Maintenance and Repair Forum
Thursday, July 28, 2005 1:24 AM
I noticed my car is dripping oil....... so I got under my car to see if it was coming from the filter, drain screw or where and I seen little dabs of oil all around the back of the oil pan, probably on like 3 or 4 screws and my puddle of oil on the ground is not like in one spot its obviously right where those 3 or 4 screws are that pin the gasket between the actual pan so I bought an oil pan gasket........I have a 1995 Z24 the 2.3L engine and was wondering if anyone has went through this experience b/c iv heard its really easy that all you do is take the bolts off the oil pan replace the gasket and your done and I have also heard its a real pain in the behind b/c the tranny is involved and everything else.............any suggestions or tips would be highly appreciated. THANKS TO ALL.
Nate Nelson
Re: Suggestions...OIL PAN GASKET
Thursday, July 28, 2005 7:39 AM
The oil pan isnt connected to anything else other then the bottom of the block.
1) You drain your oil first.
2) Remove bolts
3) Tap pan with a hammer if it doesnt fall off, BUT make sure you have a block of wood against the pan so you dont damage your pan.
4) Pull out gasket.
5) clean mounting area
6) Install nmew gasket.
7) Bolt back up
8) Torque to specs.
9) Fill oil up again.
“Facts are meaningless. You could use facts to prove anything that’s even remotely true."
Thursday, July 28, 2005 7:44 AM
BTW, i looked at your profile. I have 2 concerns.
1) Bosch platinum +4
You will have better Luck with Stock Plugs then the crappy Bosch 4's, even if they are platinum.
2) 4 gauge power wire
Your running a 4 awg wire for a 1600 Watt amp?
Thursday, July 28, 2005 8:41 AM
Tip #1: Before replacing the oil pan gasket, make sure the oil isn't dripping from another spot higher up on the engine (such as the oil pressure sending unit), then collecting on the lip between the block and pan.
Thursday, July 28, 2005 8:51 AM
ZlineDavid wrote:Tip #1: Before replacing the oil pan gasket, make sure the oil isn't dripping from another spot higher up on the engine (such as the oil pressure sending unit), then collecting on the lip between the block and pan.
GOOD point.
Thursday, July 28, 2005 10:44 AM
Lawnmowerracer wrote:BTW, i looked at your profile. I have 2 concerns.
I totally agree the Bosch platinum +4 Suck they need changed anyway, I will deffinately go back to stock. What would you suggest about the power wire! Im sorta clueless.
Thursday, July 28, 2005 12:57 PM
Check in the audio section, Specificly Ask either Lundis or Americonium. Personally id go with alteast a 2 awg.
I run a 4 awg to 750 watts.
Thursday, July 28, 2005 1:00 PM
lol i was running 4 gage w/ a 300 watt amp.
