Broken muffler? - Maintenance and Repair Forum
Broken muffler?
Thursday, July 14, 2005 6:19 PM
Hey all.... got a question
One of the small tube chambers in my muffler has broken and is loose in my muffler?
Should I be concerned about this? Besides the annoying rattle that the muffler has, what problems could arise?
<img src="http://www.j-body.org/registry/lefty/animation7.gif">
<img src="http://www.j-body.org/registry/lefty/animation1.gif">
Huh?...... I thought I started at 9:47am........not 8:00am....
Re: Broken muffler?
Thursday, July 14, 2005 7:30 PM
I would not be too concerned,as long as the flow of exhaust is normal out of the tail pipe,it should b fine.If it blocks the flow it can cause unecessary backpressure and maybe cause the car to choke a little or try to cut off.But as long as u feel the exh flow being normal I would not consider it a problem other than the noise.
Re: Broken muffler?
Thursday, July 14, 2005 8:45 PM
Thanks...
Is it possible that this could cause my engine to overheat?
Re: Broken muffler?
Friday, July 15, 2005 8:00 PM
Absolutey not, engine temps problems are normally a bad thermostat,no working fan,water pump dyeing, even a slow leak that's causing air to get into the system and cause air pockets.Typically its a thermostat sticking half closed or closed all the way or the fan not cycling on or not working for overheating issues.
Re: Broken muffler?
Saturday, July 16, 2005 7:29 AM
Thanks Ron... just what i needed to hear.
