The sunroof in my car is broken or somemthing. When it is closed yoiu can press on the back of the glass and it will lift up. Is this normal?? any ideas what would be causing this. It does open and close fine.
Mine does the same thing. I'm not worried about it. Kinda freaky though when I'm driving down the highway and the closed sunroof will slightly lift up and down with the airflow going over the top of the car. 2000 z24. But like you, I'm not sure if mine is broken or not. Anyone else?
i haven't driven it out on the highway to see what it does...but I hope that this is not normal??? anyone else
mines the same too. and when you close the door it pops up a little too right? don't
worry its normal.
the roof on our cars flexes a pretty good amount and seeing how glass doesn't i would
have to guess its so the sunroof mecinism doesn't get damaged. who knows as long as it does't leak when it rains dont worry about it.
thanks for your help guys
bringing it back....this is so annoying...any one find a fix??
(and yes I know I just posted in the exterior forum, this was at the end of the8 pages of searching)
actually i dont find that to be the case with my sunroof. i have a 01 powered ( idk if that makes a difference or not) but mine fits nice and snug, no lifting
This is normal.
It is like this so when you slam your doors it releases pressure.
Unless it's SUPER loose, don't worry about it.
cruising 65-70...it will sit there and bounce around in the back, maybe moves 1" - 2"
