Is it necessary to change the actual timing chain itself? I have all the gaskets, the tensioner, tensioner shoe and guides, can the chain be re-used? or is it likely worn at 163,000kms? I anyone who has done it did you change the chain?
<br><img src="http://memimage.cardomain.net/member_images/8/web/728000-728999/728095_1.jpg">
Yes officer I knew the speed limit was 50
if your going to tear it down to that point then change it for crying out loud. Then no worries, dont reuse it if you take it off.
http://www.ohiocichlids.com <<<<If you keep cichlids
Id change it since you have everything apart.Hey,didnt you buy the tensioners off me?Good luck.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
yeah, I haven't gotten around to doing the swap forever but I`m actually gonna do it now lol, been way too long making weird sounds dont wanna push my luck any more than i already have.
Yeah im changing mine too
Factory rebuild blew up at 30,000 miles so i bought a junk yard motor and it needs a new chain, gonna do the swapparrooski on that.
![](http://www.nwuonline.com/images/sig2.jpg)
nwuonline.com
Proud member on JBNW.org
JBO member since 2004
yeah with that much use on it might as well change it ,and go for the better piece of mind
