Rough idle/rough drive - Maintenance and Repair Forum
Wednesday, June 22, 2005 8:20 AM
I've got a '96 sunfire with a 2.2 OHV that won't run. When it did, it would have an extremely rough idle, and drove with minimal pick up. It seems to have a heat soak problem because it always breaks down once it heats up. My problem is the battery dies and all the error codes cleared, so I can't use a scan tool. I'm thinking replacing the starter motor/solenoid, and battery, even though the battery has been pretty reliable, it might have dead cells. Either way if anyone has any suggestions I'd appreciate the help.
Re: Rough idle/rough drive
Wednesday, June 22, 2005 9:21 PM
need more info please??
The starter/solenoid has nothing to do with the car once its running, so cross that out if it dies once it warms up.
Got a volt meter?
http://www.ohiocichlids.com <<<<If you keep cichlids
