Someone with a Haynes...quick wire question. - Maintenance and Repair Forum
Tuesday, June 21, 2005 5:25 PM
I can't find my manual......on the dome light that has the map lights built into it, is the black wire a constant or a ground? I wired it up, and the orange & white were color matched, but the black needs hooked to something, cuz the map lights only work when the dome is on. That is what's leading me to believe the black may be a constant power.
Thanks in advance.
Re: Someone with a Haynes...quick wire question.
Tuesday, June 21, 2005 6:27 PM
OK
my '82-94 says :-
org is +12v from rdo/ctsy fuse
wht is other side of bulbs to door jamb switches/headlight sw assy/multi function alarm
blacks are all grounds
hope this helps
Alont
