3800 v-6 misfire problems - Maintenance and Repair Forum
Monday, June 20, 2005 5:59 PM
hey guys i have a 3800 v-6 in my buddies camaro it seems to be missing on one maybe 2 cylinders when it warms up ,, idles fine under full throttl though misses real bad but if any of you know its a bitch to pull the plugs on that engine wires are fine please help i think its a bad plug or coil pack
"dude, thats a girls car"
PSHHHTTT NOT ANY MORE!!!!!!!
Re: 3800 v-6 misfire problems
Monday, June 20, 2005 11:52 PM
distributor
Tuesday, June 21, 2005 6:40 AM
i fixed a 3800 v6 buick having a problem mis firing at start-up on the 2nd cylinder. Turns out the spark plug wire was frayed a little right before the spark-plug itself. Check your wires first if it aint that youll probably have to fix the distrubutor or coil packs (which ever i dont know)
"Youre lucky that 100 shot of nos didnt blow the welds on your intake"
-Vin Diesel
Tuesday, June 21, 2005 9:10 AM
the plug wires on the 3800 camaros get carbon tracked really easy , and more so with the heat shields on the end of the plug wires
replace all the wires , and do not put the heat shields back on the end of the wires
and have fun they arent the easiest to change , even if you have the car 6ft in the air
Tuesday, June 21, 2005 10:35 PM
yeah allready did this once no heat sheilds were put back on the 3800 of that year is DIS
