How to change headlight on 02 Cavi - Maintenance and Repair Forum
Sunday, June 19, 2005 3:22 PM
What is the simplest way without taking everything apart to replace the bulbs? Every other car it takes 5 mins to change, but it looks like this is a 5 hour project to do the right way without screwing everything up. Please help!!
~Nicole~
Re: How to change headlight on 02 Cavi
Sunday, June 19, 2005 3:59 PM
its easy. pop the hood. take off the rad cover (i leave mine off so i dont have to keep removin' it) once its off, its 2 bolts for each headlight to come out. takes me about 5 mins to change 2 bulbs
Sunday, June 19, 2005 5:16 PM
The owners manual for my 2002 Cav is in the glovebox...
It's too hot to go outside and look, but I believe there
are illustrated instructions for every bulb replacement.
If your manual does not have this, then I am wrong.
Sunday, June 19, 2005 8:17 PM
^^ I cant recall either... BUT... the first time I changed my headlights I followed the directions in the owners manual and it explained it to a T.
When you get to the part that says "lift up and pull forwards" or somethign like.... do this "lift up and yank the @!#$ out of the headlight"... works better
<img src="http://registry.gmenthusiast.com/images/neo32843/personal_pic.jpg">
<A HREF="http://www.neo-j.741.com/">Visit my Website: neo-j.741.com</A>
Sunday, June 19, 2005 9:27 PM
like bagged said, its that easy and fast. Pop the hood, take off the rad cover by pulling the little tabs out, take out bolts and then pop out the assembly. Take out old bulbs, put in new and reverse the process and your done. A 10-15 minute job, tops.
'02 LS Sport - Indigo Blue
