CV shaft... - Maintenance and Repair Forum
CV shaft...
Monday, June 13, 2005 8:58 PM
How would you know when one is going bad? I've been told clicking noises... Can't really hear them over an aftermarket exhaust and intake. Also when i have more people get in my car i have shudders while accelerating that get worse when more people ride in the car. When its myself they are not bad. Also Somthing is causing high speed vibrations. I've had new tires put on, balanced and re-balanced, new wheel bearings.
Re: CV shaft...
Wednesday, June 15, 2005 8:24 PM
bump
Re: CV shaft...
Wednesday, June 15, 2005 8:52 PM
It could be. thumping and clicking. Inner ones when accelerating. outer joints when turning.
My Car
Re: CV shaft...
Wednesday, June 15, 2005 9:20 PM
I just don't hear then clicking.... Then again my wheel bearing never growled or nor was i able to move them around with the wheel on, but when i took the driver side out it had alot of play in her.
Re: CV shaft...
Thursday, June 16, 2005 9:13 AM
have you checked the boots to see if any grease has leaked out?
I know that when i tore one of mine up, i would hear a clicking sound when coming to a stop.
Re: CV shaft...
Thursday, June 16, 2005 9:16 AM
turn the wheel all the way to one side, then drive the circle, repeat for the other side.
http://www.ohiocichlids.com <<<<If you keep cichlids
Re: CV shaft...
Thursday, June 16, 2005 1:00 PM
When i first start the car up in the morning, i have a clicking noise comming from the front that has gotten worse since winter... but i always thought that was due to the cold weather. But its also now doing it in 60 degree weather and i can really only hear it when i start driveing but it goes away after the car warms up... hmmm...
