hello well ive had my intake installed for awhile.. but i posted up here awhile ago about my car bogging out when its cold.. so i thought it mite be the sensor that goes into the intake.. i took it out and it looked like it mite not be in enough to have air "flowing over it" so i cut a piece of the rubber off my aftermartket intake so it would sit in the intake more.. anyway after i plugged it back in i got a check engine light?? i heard if u leave ur keys in the ing. with it not running but "on" that it resets something anyway wondering what else i can do? i have access to a tech-2 if need be but hopefully can do something now?
if the IAT sensor is not all the way into the bung in the intake it will throw a code. what intake kit do you have?
i have cosmo racing one.. ive been out there fiddling with it right now.. i unplugged it a couple times and plugged it back in does it take awhile for it to reset the code or?? im thinking if i drive it tomorrow it will go off.. atfirst i unplugged the IAT sensor.. looked inside and no light..i dont even know why i checked i just did..lol anyway i plugged it all back in and stuff and now i get a light still ive turned it on and off and all that junk that i thought could help but its still there has to be the sensor.. i added coolant and did that thats it..
first find out what the CEL is. it could be something else ( highly doubtful) but its possible.
take off your neg bat. terminal leave it out for 15-30 mins. and push your brakes a couple times.(to release any current in the wire)
that will reset your ECU..or at least it should.
then see if your CEl comes back on
Spotabee Racing wrote:if the IAT sensor is not all the way into the bung in the intake it will throw a code. what intake kit do you have?
wrong! on my weapon r intake it's not all the way into the bung (damn near impossible the way they the intake is made without some custom work) and my car isn't throwing any codes.
SO EVERYTHING!
