My drivers side high beam is out the low beam is fine i changed the bulb and checked the fuses and they are fine does anyone have a idea on how to fix this.
DO you have the right bulb?
true.
Cannon fodder is my daddy.
Check the power feeds to the bulbs. I had a similar problem on my 99 sunfire gt, and the power feed to the passenger bulb was broken, I fiexed it, and no more problems. just check all the wiring, and you will probably find a broken wire.
Do your DRLs "strobe" when you put your car in gear? If so, this will cause the drivers side light not to work. Check your DRL realy if you get this problem.
Otherwise, what he said ^^^
-- The The One One --
<IMG SRC="http://registry.gmenthusiast.com/images/neo32843/personal_pic.gif">
could be wires....just had a bunch of corroded wires replaced on mine to get the DRL's to work and the driver side High beam...
--04 Blazing Copper Mazda 6 s
I told someone how to check the wires in
this thread.
This might help fix your problem.
^^^ same problem about 6 mos ago... fixed 3 corroded wires with a few pieces of wire, and a soldering iron..its a pain to get the soldering iron down there, but it worked..
