crappy gas pedal - Maintenance and Repair Forum
crappy gas pedal
Sunday, April 24, 2005 6:35 AM
my g/f's Cavalier, when you first go to step on the gas pedal, it feels stuck and you have to press harder than usual. It sometimes causes you to launch at a stop light lol.
http://www.ohiocichlids.com <<<<If you keep cichlids
Re: crappy gas pedal
Sunday, April 24, 2005 8:21 AM
sounds like it may have carbopn build up at the TB.......usualy worse cold then gets better when its hot
Sunday, April 24, 2005 9:49 AM
its just that one spot though, when first push the pedal, once you have it pressed, its easy. How do you suggest I fix this? I was thinking it would be in the pedal assem. itself.
Sunday, April 24, 2005 10:37 AM
Im also say clean the TB
<img src="http://geocities.com/jimmythekid1/gecat2.gif">
Sunday, April 24, 2005 12:04 PM
with what, just a spray? I dont like adding things to the tank.
Sunday, April 24, 2005 12:05 PM
when you first press the pedal is when the carbon in the TB is broken free.......after that it will be fine.......start with cleaning the TB and go from there
Sunday, April 24, 2005 12:13 PM
and if its not that? Do you know of any good products to try?
Sunday, April 24, 2005 1:33 PM
use carb cleaner
