this is most likely a worthless cause, i'm looking for tool j41088. a picture found here.<a href=http://www.emulsified.net/upload/pics/bst.jpg)a picture found here(/a>This tool allows u to install the balance shaft chain to the crank, and appears to be the only way (shy of fabricating your own) to time the balance shafts correctly. so if anyone can find an online/local retailer, etc. or even lend me for a fee and collateral i would GREATLY appreciate it. anything to help me get closer to tracking this tool down or another installation procedure someone has taken to do this will be awesome.
this is most likely a worthless cause, i'm looking for tool j41088. <a href=http://www.emulsified.net/upload/pics/bst.jpg>a picture found here</a>. This tool allows u to install the balance shaft chain to the crank, and appears to be the only way (shy of fabricating your own) to time the balance shafts correctly. so if anyone can find an online/local retailer, etc. or even lend me for a fee and collateral i would GREATLY appreciate it. anything to help me get closer to tracking this tool down or another installation procedure someone has taken to do this will be awesome.
sorry about the double post...
The second one was better anyway.
Why not just us a straight edge across the flat part of the shaft, then a triangle on the block base to make sure your straight edge is perpendicular to the crank. Clamp that all up and go put the chain on. Crude, but works.
-da chinchilla
<img src="http://registry.gmenthusiast.com/images/jiggamon/avatar15569_2.gif">
Thats what i did,but i used a screwdriver to line them up.I wouldnt buy a tool like that if im only gonna use it once.The only tricky part is getting the right tension on the chain for the oil pump.
Peter
Gm Stage II W/2.79" Pulley
K&N Drop In Filter
Custom Magnaflow Dual Exhaust
can u tighten the bolt that way too?
________________________________________________
...bone stock
check the big three tool companies Snap-on, MAC, and matco, they all have web sites check it out.
1979 Impala Sport Coupe Aeroback
