Throttle Clip - Maintenance and Repair Forum
Throttle Clip
Wednesday, March 30, 2005 11:39 AM
I had to do a valve gasket this morning and i found that the clip that holds the cable to the black bracket is broken. I tested it and it wont slide off under normal use i would just like to secure this down. Its a 97 2.2L Motor. Let me know if this is somehting i can go to the auto parts store and buy or should i just go get one at the junk yard. Also what is the part called?
Celebrating 4:20 Just a little early................
Re: Throttle Clip
Wednesday, March 30, 2005 1:47 PM
same thing happened to me .. i just used a white nylon zipper thingy and secrured it.
Re: Throttle Clip
Wednesday, March 30, 2005 3:03 PM
its called a wire tie or a "zippy tie"
HONDAS ARE LIKE TAMPONS…EVERY PU**Y NEEDS ONE!
