Changed Coil packs this morning and now the car runs worse than yesterday
Now the car shudders majorly, popping noises still occuring but now more frequently! Stalls or dies sometimes when stepping on the gas. slow acceleration! the muffler is now starting to putter
Spark plugs are tight and gapped properly! New Spark Plug wires seated properly!
Coolant level normal. Oil level good. Transmission fluid good. I can hear the fuel pump as I always have.
What else have I not thought of? fuel injectors?
Good...Better...Best!...Never Quit, Never Rest...Until the Good Get Better and the Better Get Best!
why did you replace the coils in the first place?
<img src="http://img.villagephotos.com/p/2003-11/504808/z28.jpg" width=317 height=59>
you got the plugs in the right order ?
<img src="http://registry.gmenthusiast.com/images/wrecked92/sig3.jpg">
i have a 2002 cavy with the 2200 and the wires going to the ign module shorted out on the module bracket. I had a miss from hell and new plugs and wires and coils did not help . went to the Chevy dealer and this is what they said "scp diag p0300 dtc and running condition due to shorted ckt 406. the wire was shorted at ign module bracket. cars runs like new again.
Lj wrote:you got the plugs in the right order ?
i think you mean " does he have the spark plug wires in the right order'
LISTEN BRO...CHANGE UR IGNITION MODULE!!! ITS THE IGNITION MODULE!! i had the same EXACT problem with my car, changed plugs, wires, coils and the same problem occurred......changed the module and the car ran great!! DO IT and let me know how it turned out
Nathan S. Nace
Changed the igniton module yesterday...$156 at Autozone...put it on....didn't fix problems!!!!
Will focus on fuel injectors now
greendragonsix wrote:Changed the igniton module yesterday...$156 at Autozone...put it on....didn't fix problems!!!! Will focus on fuel injectors now
yeah the ignition module opens the primary in the coil, so the voltage jumps to secondary. That would usually result in a crank no start, i wish I would have read that before you wasted your money on a module.
You have already wasted enough money take it to a professional. Or if you have a friend with a scan you can use it to find the miss with the misfire counter, to isolate the missing cylinder. Throwing parts at it is stupid if you don't now what your doing pay some one who does.
1979 Impala Sport Coupe Aeroback
Thank you for saying that, that line should be said more often on this board... espicially when people say things like
LISTEN BRO...CHANGE UR IGNITION MODULE!!! ITS THE IGNITION MODULE!! and then it isnt the ignition module.
