Recently my CEL came on and turned out to be a misfire on the 3rd cylinder. What are my options to fix this.I will be getting spark plugs tomorrow. If that doesnt work what else can I try? Thanks
Definitely replace your plugs first. Then check your wires.
To check your wires, start your engine, and then pull each of your plug wires from the plug, and hold it close to the engine. If it is working right, it should visibly [and audibly] spark onto your engine block. If not, see if the other cylinder on that coil is firing by doing the same thing. If it's firing fine, you probably have a bad wire. If it is not firing, they you have a bad coil, or a bad ICM.
What is the mileage on your car?
--==pghcavman==--
my car is almost at 105,000. As soom as I get out of school I will check those things. Thanks
96-98 2.2l #2 cyllinder plug wire is notoriously none to fail!!!! that's from a GM tsb.
If at first you don't succeed, destroy all evidence you tried!
^^^^^^^oops....so I agree with pghcavman.....check your wires!!
