What motor oil is the 98 sunfire 2200 supposed to use? I believe i have 10w30 in the car right now. Its also cheveron brand. What bennefits will using a motor oil like royal purple, redline, or havolines racing revolution have? And should i just stick with regular oil and not synthetic and is 5w30 better? I live in cali and it never gets to cold.... if that makes a difference on oil grade
98' Pontiac Sunfire SE
never use 10W30 run mobil 1 5W30 in the summer and mobil 1 0W30 in the winter and i kno all of this becuase i work at a mobil 1 trust me and don't use fram oil filters use k&n or mobil 1
How well do the K&N oil filters work?
GM says you should use 5-w30 in cold climates, and 10-w30 in warmer climates. For normal street use, Mobil 1 10w-30 should be fine. I doubt you would notice any gains over mobil 1 and something like amsoil or royal purple. Use a decent filter like ac delco.
It all depends on what kind of driver you are and how many miles are on the car too. If you have a heavier foot, you should run a thicker oil. More miles... use a thicker oil. I personally run 15w40 in my car but it has a lot of miles, a slight oil leak, and a little bit of burnage. A thicker oil also doesnt burn off as fast as thiner oils do. You dont have to use a K&N or M1 oil filter.. If you change your oil regularly, you shouldnt have a problem. Yes they do a damn good job but $10 is steep for a damn oil filter. You're only talking about a j-body... not a hot rod or sports car.
Oh yeah... and as for oil brand... they're just like generic meds, when it all boils down they're the same on the inside (unless it's synthetic).
15w-40 yea and look at his car and how it runs u should never use that ask any one go with 10w-30
My car probably runs 100x better than your girlfriends.... SINCE YOU DON'T HAVE A CAR!
i have a 95 sunfire sittin waiting for me to gfet it back and it it isn't better then my g/f 's for one it doesn't burn oil or leak it nore does she have a pink car or purple or w/e it is so look at whoes runs better and looks better
I run 5W-30 Walmart cheap brand with Fram oil filters on a 2.2 Cavalier. I bought the car new in 2000. Its has 104,000 miles on it. No leaks, no engine problems. Still sounds like the day I took it off the lot.
I change the oil every 5,000 miles religiously.
I use Havoline 10W-30 and change @ 3,000 miles. Live in a warmer climate(Richmond, VA) I also use the ACDelco PF-47 filter.
God bless America.
justin rockwell wrote:i have a 95 sunfire sittin waiting for me to gfet it back and it it isn't better then my g/f 's for one it doesn't burn oil or leak it nore does she have a pink car or purple or w/e it is so look at whoes runs better and looks better
ahahahahahahaha.
hope the mobil station has a good retirement plan
<A HREF="http://www.cardomain.com/id/eazy716"><IMG SRC="http://registry.gmenthusiast.com/images/eazy716/personal_pic.gif" BORDER="0"></A>
dude shut the @!#$ up, a pink cavaier is better than a bitch ass sunfire, come on now, who dreams of having a boosed sunfire
BEATER: 95 talon Tsi AWD
and who the @!#$ asks about motor oil? oil is oil
lmfao @ corey
You dont have a single clue about my car... How many miles are on it?
don't need to kno look at it ...it's pink @!#$ up body and i could care less how many miles are on it .......yea and like a pink cavalier is better then a sunfire .....
yea your cool
justin rockwell wrote:never use 10W30 run mobil 1 5W30 in the summer and mobil 1 0W30 in the winter and i kno all of this becuase i work at a mobil 1 trust me and don't use fram oil filters use k&n or mobil 1
i thought you got fired for puting in the wrong filter on someones car, and killer the engine? care to explain
justin rockwell wrote:don't need to kno look at it ...it's pink @!#$ up body and i could care less how many miles are on it .......yea and like a pink cavalier is better then a sunfire ..... yea your cool
you know what i find funnier than the color of his car. the fact that your mommy told you that you cant go to the car show. i remember the days of having mommy tell me what i can and cant do. WHEN I WAS 12. I guess that explains the no license or car.
hows that Huffy treating ya.
use mobil 1 if you want to run synthetic if not...use Valvoline
never use penzoil unless you want wax buildup
dude, Joe, Justin and Cooter, why the hell do you guys always jack other peoples threads? End the fawkin bull@!#$. This is starting to get rediculous.
Simply J's of MD
Pop N Fresh wrote:dude, Joe, Justin and Cooter, why the hell do you guys always jack other peoples threads? End the fawkin bull@!#$. This is starting to get rediculous.
That @!#$ piece of @!#$ Justin started this @!#$.
sorry Cooter, didn't read it all the way through. Now that i have, i retract my previous statement. But in any case this @!#$ should still stop, settle it elsewhere
Simply J's of MD
