Hi all,
I have a Pontiac Sunfire 2003
2.2L Ectotec
What I've done so far:
Throttle body cleaned replaced IAC, MAP sensor, Fuel filter, Fuel pressure regulator.
When I check fuel pressure I get 50psi.
Spark plugs were changed
No vacuum leaks.
I'm at a loss....
Have you tried pulling the battery cable for a few minutes to reset the stored data in the PCM? Compression test?
"In Oldskool we trust"
Yes, I did a reset, didn't work.
How do I do a compression test on an Ecotec??
I did a compression test today and came out with 149 on all 4 cylinders with dry test.
But I came out with only 150 wet again all 4 cylinders. Did that come out right?? I put a cap full of oil in each cylinder when I ran the test...
Is your check engine light on?
What rpm does it sit at?
Nicholas Reilly wrote:Is your check engine light on?
No check engine light
When I'm at the stop light it sits at around 500 or 600 rpm
Update:
Car is stumbling more when I stop, today on my way to work it almost concked out on me...
It is an auto right? How is the fluid level?
I know a problem in the older cavaliers was a torque converter locking solenoid would start to go, causing bad idle in gear from it trying to lock the converter. Could be a problem with that.
