Fan stuck on - Maintenance and Repair Forum
Fan stuck on
Thursday, May 01, 2014 7:33 PM
So I have been having this issue intermittently that has my radiator fan stay on as soon as the engine is started. When I turn on the A/C that would normally kick the fan on, the fan still stays on as it should. When I turn off the A/C, the fan stays on. It caused me to throw P0128-Powertrain. Coolant Thermostat. The fan has done this three times in the past week, but has not done it for two days now. Could it be the relay?
Re: Fan stuck on
Thursday, May 01, 2014 7:58 PM
The coolant temperature sensor malfunctioning in a certain way will throw the fan on all the time. This sensor won't usually throw a code tho. The sensor is located in different spots depending on your motor. Also, does the temp gauge work?
Re: Fan stuck on
Thursday, May 01, 2014 9:48 PM
Temp gauge works just fine. The code was for the thermostat not opening up while the engine was running because of how low the engine temp was staying at (130*-140*F) the whole time. It's a 2003 with 180,xxx miles.
