Clutch wont engage - Maintenance and Repair Forum
Clutch wont engage
Thursday, February 20, 2014 11:10 AM
I replaced my clutch, pressure plate, slave cylinder, and master cylinder and bled the system. Now the clutch does not seem to be engaging. Pedal feels good but the trans wont go into gear. Any suggestions?
Re: Clutch wont engage
Tuesday, February 25, 2014 4:35 PM
it wont go into gear with the engine running or just sitting doing nothing?
Wednesday, February 26, 2014 9:28 PM
A 1st gen guy.However did you bench bleed the master and this can be a reason the slave is not engaging the throw out.I would rebleed the system and assuming no mishaps like the throwout(release bearing)was not installed backwards.Also was the pushrod for the master adjusted assuming again this is doable on the gen you have.Axle shafts seated correct?Just presenting ideas while maybe helpful or not quiet applicable to your model things I thought of.If I am incorrect may others add/correct me if necessary.
