ok I've been having a anti theft problem for a bit and cant figure it out, at first it was no gauges (TAC, GAS SPEEDO, TEMP) at all worked but all the back lighting worked and I could still drive, so because all my fuses and grounds were good I figured it must be the tumbler, so I bought a new 1, switched it and did all the nessary steps to get it running but now it won't stay running, also everyone says that when u do this the anti theft light should flash, but mine doesn't even light up now at all, and before I switched the tumbler my stereo worked and power trunk didn't , now its the opposite?? any help or advice? I'm all ears (technically eyes lol)
![](http://carphotos4.cardomain.com/images/0015/52/10/15982501_medium.jpg)
Skr8 Goodz in tha hood
No one here kno's anything about Cavalier 03-05 Cavalier Anti-theft????
Cavalier Thompson wrote:No one here kno's anything about Cavalier 03-05 Cavalier Anti-theft????
dont kno how i got Cavalier in there twice but whatever lol
Try doing a relearn. There is resistance in the yellow and white wire undernieth the ignition switch. That has to be relearned. You can look up passlock bypass. You can buy pass it with a resistor or a gm automatic learning bypass kit for your year and model. I do it all the time with remote starts. I would try a relearn first though.
tryed that 10 times over but still nothing, me and my friend been goin over it with a fine toothed comb, checked fuses, ignition wires broke anywhere even disconnected my alarm and switched his computer, tumbler and cluster from his beater to my car and no go but I did find this New Rockies full bypass module on google searching solutions for this but never heard of it before so I'm kinda iffy on trying it it,
http://newrockies.com
Did you check the gauge cluster fuse? If the lighting works, but the rest of the cluster doesn't... probably has no power.
checked every fuse with a volt meter twice and my friend checked them twice, they all worked, unless that fuse is somewhere else in the car
just wondering if anyone would kno if I switched my Cluster, Tumbler, BCM and PCM from a junk car the same year and drivetrain as mine, would that get my car running??
