the last couple days when I go to work around 7am my abs, E-brake and anti theft light has been popping on for no reason but last night my anti theft came on and stayed on, I have cluster lights but none of my needles work and my door pins don't work when I turn the car off because my Jvc deck still plays after the doors been open, anybody ever have this problem or have any tips on how to go about fixing this?
Skr8 Goodz in tha hood
I had it happen once I just unhooked the negative cable to my battery for 15 minutes and hooked it back up then started the car and all the needles worked again.
If the theft light it on that usually means that it is fail safe mode, disconnecting your battery before you diagnose the problem could lead to a no start situation.
did the negative battery disconnect and still nothing and how do I go about searching the problem?
Sounds like either a bad ground or a bad cluster.
