ignition switch failed... wanting to go push button - Maintenance and Repair Forum
Monday, April 22, 2013 7:58 PM
as stated i want to go push button for the starter and probably run the ignition and accessories on a switch or 2. is there someone that has done it that can explain what i have to do to make it work or has someone done a write up on it? I need info on how to go about doing this before i go tearing into it and break somethin else
94' Camaro z28 a4= bolt-ons and cam
91' Cavalier z24 a3= stock DD
Re: ignition switch failed... wanting to go push button
Monday, April 22, 2013 9:39 PM
why not do something crazy and, oh, i dunno, FIX the issue? a new ignition switch is like $30. to go pushbutton with switches will cost you at least twice that in parts, then wiring, then diagnosis time, then more wiring, then you'll realize it wasnt worth it and do that @!#$ the right way.
just sayin.
Tuesday, April 23, 2013 8:16 AM
Capn Bloodbeard wrote:why not do something crazy and, oh, i dunno, FIX the issue? a new ignition switch is like $30. to go pushbutton with switches will cost you at least twice that in parts, then wiring, then diagnosis time, then more wiring, then you'll realize it wasnt worth it and do that @!#$ the right way.
just sayin.
i can do this for free, i have all the parts i'll need laying around in my shop. but i didnt know the ignition switch was so cheap... frankly $30 is the cheapest igniton switch ive ever heard off...
Tuesday, April 23, 2013 8:25 AM
Last time I bought one it was about $40.
Tuesday, April 23, 2013 3:43 PM
You will have a lot more issues than you think. A lot more goes on inside the key switch than just on/off/start
Have a nice day.
Tuesday, April 23, 2013 3:54 PM
Having actually pulled apart an ignition switch for a third gen, It doesn't actually do much more then on/off/start. There is a cam in the switch that spread the contacts apart or lets them touch depending on the key position. Take your bad one apart and you will see.
Push button start, on my 95 it was a thick yellow wire and a thick purple wire.
Thursday, May 16, 2013 6:50 PM
well I ended up tearing it apart and fixed it correctly lol. it ended up being the key lock cylinder which is like $160 at oreillys ... damn lol
Friday, May 17, 2013 1:30 PM
Always check Rockauto.com for parts before you buy. You can usually get MUCH cheaper prices for the same name brand parts. However, their cheapest V6/91Z24 ignition lock cylinder was around $115..so yeah thats a pricey fix.
or eBay/Amazon, but check fine print and make sure its not a refurb (which are perfectly fine) if you want new or ensure it has a warranty.
but nice job on doing it right. i still think a push button would have more complications than doing it the right way, but we dont modify because its always the right thing to do...lol
04 Cav. 2dr. 5spd. My DD. 'Nuff said.
Saturday, May 18, 2013 8:00 PM
at least buying it local you were covered if anyhting happens. Instead of waiting for them to mail you another one.....
