Tie rod end boot appears to be torn? - Maintenance and Repair Forum
Monday, March 04, 2013 3:22 PM
I believe the boot on the drivers side tie rod end finally tore. Tried researching, but it doesn't seem like anybody sells just a replacement boot. Am I going to have to buy the whole end, or can the boot just be replaced? Also, does it look like the tie rod is sitting normally? I haven't noticed any steering problems. Thank you for any insight you can share!
Re: Tie rod end boot appears to be torn?
Monday, March 04, 2013 8:05 PM
Napa sells replacement boots based on size of the shaft end. They won't be listed vehicle specific, but they do have them. I work there.
Friday, March 22, 2013 7:09 PM
honestly i wouldnt touch it until you experience problems... mine are torn and have been for a while eventually loose grease and wear out faster but that case ill replace the whole
