In need of help ASAP - Maintenance and Repair Forum
Friday, February 01, 2013 8:43 PM
I have a 1998 cavalier 2.2 5 spd Well about two weeks ago my car got brOken into and shortly after it started sputtering an falling on its face and it shut off while I was driving it. It turned over but wouldn't start so I waited about a half hour then it started right up and I was halfway home when it seemed like the thrOttle cable was gone it was idling but when I hit the petal it wouldn't rev up so I pulled it home. I let it sit all night and went out the next day and it ran fine like nothing happened so I drove it for two days before it acted up again. It would run then shut off like someone just turned the key off so I babied it home. So here's where I'm at i turn the key on and the fuel pump don't kick on but if I jump it with a wire at the relay the pump kicks on and I have spark so does anyone have an idea of what it could be? I'm completely stumped
Re: In need of help ASAP
Saturday, February 02, 2013 11:51 AM
If your car was broken into id suggest looking at your ignition switch..
The leg that powers the pump relay could be damaged. Any evidence of tampering?
Saturday, February 02, 2013 8:52 PM
Ya ignition switch is a good idea. Based on the description of events you make want to look into a crank sensor too, cause same to me as is to you minus the whole car stolen thing. Very sorry to hear that too, don't suppose you got it back because they caught the guy.
Z doesn't mean last, it just lapped A.
Sunday, February 03, 2013 8:36 AM
Ok I bought a crank sensor but haven't put it in yet because I don't wanna do like I did my truck and just keep buying things for it and end up investing 1000 dollars and I don't think they tampered with my ignition and no they didn't catch the guy but if I caught him he wouldn't be feelin to good after I got done. I'll put in the crank sensor and check my ignition and let you guys know what happends from there
Sunday, February 03, 2013 5:43 PM
Ok well I crawled under my car to change the crank sensor and noticed a wire was bare and laying on the half shaft I do believe it's called and wasn't sure if that could be my issue. it runs back toward the back of the car kinda buy the exhaust
Sunday, February 03, 2013 7:54 PM
Crank sensor harness?
Monday, February 04, 2013 10:46 PM
No I found it ran to the o2 sensor but what's the best way to get the crank sensor out because it broke off flush with the block and it also kinda looks like where it broke off the plastic was fried like it shorted out and I wasn't sure if that was a possibility?
Tuesday, February 05, 2013 9:29 PM
well update.. for some odd reason my fuel pump decided to start working again and found out my battery is shot but still can't get my cps out
Tuesday, February 05, 2013 9:55 PM
Hit it like a man bro!
Wednesday, February 06, 2013 9:27 AM
haha yeah right.. my big assets barely fits under the car let alone move around
Saturday, February 09, 2013 9:04 PM
Kind of a redneck suggestion...but maybe drill a pilot hole, screw a small screw in it, and PULLL! lol. Not saying it will work, just a suggestion.
"If I'm not back in 5 minutes...just wait longer"
Monday, February 11, 2013 9:51 PM
Haha thanks for the suggestion but I just ended up pulling the engine and dropping the oil pan. Now time to see if it runs tOmarrow after buying a new battery it fixed most my issues it seems
Wednesday, February 13, 2013 2:47 PM
well its still messed up here's where im at.... i turned the key and the fuel pump kicked on and then it wouldn't turn on after that so im thinking its either the ignition or a broke or loose wire but im not sure so any ideas would be nice thanks
Thursday, February 14, 2013 5:38 AM
Does it crank and not start? Or not even crank?
-I drive my car to work-
Thursday, February 14, 2013 11:18 AM
Uhm..... bad fuel pump relay? Try swapping the relay with one of the other ones and see what happens.
Thursday, February 14, 2013 12:38 PM
It cranks over fine and does not start and ok I'll try the relay idea
Thursday, February 14, 2013 5:29 PM
Ok well I'm not the best with electrical but what wires on the relay should be hot when the key is on?
Tuesday, February 19, 2013 8:59 PM
Well my car is fixed it was a simple broken wire lets hope it stays fixed
