Daylight Running Lights - Maintenance and Repair Forum
Saturday, July 07, 2012 6:15 AM
Has anyone had problems with the day light running lights? The bright indicator stays on, the right side is working good but the left side is dim and when you switch the head lights on the left side still stays dim. Brand new bulbs, checked the fuses ect.
problem is I need them working in my province!
I know GM had an update to the wiring harness for the lights on the left side. This was already done by the original owner.
Any ideas??
Thanks
Re: Daylight Running Lights
Saturday, July 07, 2012 8:08 AM
wow this is like a major issue around here lol. you, me and some other guy all this week!
anyways, what i did was changed my "LTHDL" fuse in the dash panel. fixed it immediately.
but if that doesnt do it, change the DRL relay (located in same panel).
I choose the technology built for land speed records... not the technology built to save on emissions and gas mileage.
Sunday, July 08, 2012 6:53 PM
If that does not work you have to take the wires out of the housing and play around with them. One of the wires were probably soldered the wrong way in the bulb its self. Bulb defect. If non of that works then I have no idea.
Stainless steel lines? Who needs them? Just don't brake O.O
