Orange-colored "syrup" in A/C lines - Maintenance and Repair Forum
Friday, June 15, 2012 9:11 AM
Yep, I'm a noob, and I need help. I have been dissembling my engine and noticed that when I removed my A/C lines there is an orange-colored "syrup" stuff that dripped out of the lines. What is this, and is it normal? Thanks in advance!
Re: Orange-colored "syrup" in A/C lines
Friday, June 15, 2012 4:07 PM
Ultra voilet dye. Used for finding leaks.
Sunday, June 17, 2012 5:33 AM
Thank you Jordan. Is that stuff a problem later on? In other words, is there any need to clean out my lines & canister?
Sunday, June 17, 2012 10:19 AM
No, you shouldnt have to. Just find a way to cap off the lines and fittings on the compressor so you dont get anything in there. Generally the dye doubles as oil/lubrication for the system. Its really a hastle to flush lines, if you didnt have any problems with the system before then I'd leave it.
Monday, June 18, 2012 7:26 AM
Great, thanks again!
Wednesday, June 20, 2012 12:20 PM
If you had the dryer (canister) unhooked and open to air, then it's no good. You will need to buy a new one.
Wednesday, June 20, 2012 12:50 PM
Mike wrote:If you had the dryer (canister) unhooked and open to air, then it's no good. You will need to buy a new one.
this includes opening the ac system in any way.
Wednesday, June 20, 2012 4:47 PM
@ Mike:
Yikes. Can you explain why?
FYI, I unhooked the system at the firewall, and also right where it connects near the radiator...
Wednesday, June 20, 2012 6:17 PM
PAUL SEELY wrote:@ Mike:
because as soon as you open the system to atmosphere, the drier begins absorbing moisture. any time you open the system, you have to replace it.
Wednesday, June 20, 2012 9:27 PM
never heard that before. I try not to keep any system I work on open to the elements for long, but never heard of a dryer being bad from being open to air.
