starting problem - Maintenance and Repair Forum
starting problem
Thursday, April 19, 2012 5:40 AM
i have a 2001 chevy cavalier z24 and ive replace the ignition switch and the starter and when i got to run it over i get nothing. after i turn it over a couple times it finnaly starts. it dosent always do it though. when i replaced the ignition switch about 6 days ago it worked fine until now. help!!!
Re: starting problem
Thursday, April 19, 2012 7:40 PM
Is your fuel system is clean, and change fuel filters every year?
Sunday, April 22, 2012 10:04 AM
i just changed my fuel filter not that long ago, like 4 months. but when i turn the key to the start position the starter does not even click. i replaces the ignition switch twice and the starter one time. it is still doing this
Sunday, April 22, 2012 11:04 AM
Did you replace the solenoid too?
It could be the relay then, if nothing clicks and cranks.
Sunday, April 22, 2012 12:35 PM
i bought a whole new starter so yea the solenoid is new and where is the relay located. will it throw a check engine light if the relay is bad. also where can i get one at the local car quest or do i have to get it from a dealership. thanks
Sunday, April 22, 2012 2:14 PM
No. I think the bad relay will not affect the engine light.
Not sure about where your relay is, if you can post a picture of under the hood we can tell you.
I have the base model '97 with 2.2, but probably similar. Mine is under the hood, there is a long square plastic box that holds a
few relays and huge fuses.
The auto parts stores should carry the relays.
Sunday, April 22, 2012 4:14 PM
This is the relay box in my cavalier
Sunday, April 22, 2012 5:10 PM
that is where my box is to but my ignition relay is not in there. there is an ignition fise that was corroted but i cleaned it an put vasolean on it so it would not corrode again
