My fog lamps stopped working last night. When the switch on the dash is turned on, the light on the switch lights up. Would it be the fog light relay or the BCM causing the problem?
Could be a relay. could something simple the switch is no good.
Where is the relay located on the '05? Also, the fog lamp fuse was not blown...
I managed to find the relay. It's located behind the driver's side front signal light. With a bit of troubleshooting and the schematic, I found the problem and got the lights to work.
You found the problem, what was it, someone in the future might need the info to help them fix the same problem on their car, so it would be helpful to post the answer.
