i think i have a shifter cable problem - Maintenance and Repair Forum
Tuesday, October 04, 2011 12:54 AM
ok so over this year going left to right in neutral is getting to be a problem with out some force i say have a problem with the cables, what do you all say? its my 99 z24
Re: i think i have a shifter cable problem
Tuesday, October 04, 2011 11:25 AM
check your bushings n stuff on the trans and under the console.. that could tell you alot
Tuesday, October 04, 2011 2:05 PM
well i unhooked the cable at trans and levers move as easy as ever
Tuesday, October 04, 2011 8:48 PM
can you clarify, when unhooked does the mechanism on the trans works easy or the shifter assembly moves easily?
Tuesday, October 04, 2011 9:34 PM
sorry i was rushing but i unhooked the cable from the trans and trans works easily .....while the shifter stayed stiff <------n------>
Wednesday, October 05, 2011 10:39 AM
Well then i'd check your shifter bushings and linkages under the console, just take the knob off and pop the plastic up and slide it off so you can see what your shifter is doing under there. Another good place to check is where the cables go from the interior through the firewall to the engine bay, they can be seen easily from under the car or even down he backside of the engine. basically look for anything that looks wrong.. like any wear on the outside of the cables or kinks tight bends etc.. that would limit the cable travel.. I think most cables are all plasic on plastic so you can't get corrosion but i'm not sure, haven't ever looked at one in depth.
Thursday, October 06, 2011 10:58 AM
i got new cables shifts perfect while the old cable <---n---> is very hard to move even when straightened out of the car and other one moves freely
