I have had my car 6 months . and here is what ive replaced. engine now has 138k clutch and hardware. brakes wheel cylinder tires alternator water pump fan ball joint tierod cntrl arm bushing reverse switch thermostat axle . front struts are fine for now . rear shocks seem ok but will be done sorta soon . all accesories are ok and pinion bearing is new . am I running, out of things to fix? what else are commom failures that I should know about?
i know for me the most common have been motor mounts,lock cylinder and fuel pump
fuel filter. one of the things that gets forgotten about the most
didnt think this was necessarily maintenance unless replacing my engine was maintenance . in my book that was a job I shouldnt of had to do and was not maintenance at all but I digress. fuel filter doesnt look to be old but I haven't done it.
