Changing the struts.... - Maintenance and Repair Forum
Saturday, July 02, 2011 5:40 AM
Need help with the comments on the image. Thanks
Pat
Re: Changing the struts....
Saturday, July 02, 2011 8:05 AM
use some PB Blaster on them, i had to use a 3lb sledge to get my knuckle bolts out
Saturday, July 02, 2011 12:15 PM
Finally got the strut bolts out, but ended up cutting and buying new sway bar links.
Saturday, July 02, 2011 2:19 PM
i usually just thread the nuts on backwards till they're flush with the end of the bolt, and swing the biggest hammer i can find.
Saturday, July 02, 2011 3:34 PM
I would put a jack on the control arm and jack it up a bit, it relieves tension from the bolts, and the nut that keeps spinning, pry it away from the end link, and try, its hard work, but you can do it.
