check engine issue - Maintenance and Repair Forum
check engine issue
Thursday, April 28, 2011 8:53 PM
hey every one im new to this site and need help don't know if its already been hit on but this is my issue. if idling to warm up the car runs fine, as soon as it hits the first line it troughs a check engine light and the fan comes on, idle for about 1-2 minutes fan turns of and so does the check engine light. will driving the car shifts to third and starts cutting out and running rich with a check engine. its a 95 cavalier with the 2.2l and cant seem to link to the computer all fuses are fine and all wires from , too the ecm are good and ecm is fine just put a new one in there.did a compression check and all is good 150 140 150 140, also just replaced the temp sending unit as well. if anyone has had this issue please let me know what you found out thanks
Robert
Re: check engine issue
Friday, April 29, 2011 7:33 PM
re
Sunday, May 01, 2011 10:18 PM
what's the check engine code?
___________________________________________________________
2001 Chevy Blazer
4.3L 5 speed manual
Alpine deck, Type R 12in. sub.
145k miles
1997 Pontiac Sunfire
2.2L automatic trans
146k miles
Monday, May 02, 2011 4:15 AM
this happend when i put my intake on..and tryed to drive my car without the mass airflow sensor or watever sensor is on the side of the intake...check that sensor and go have a auto parts store reset ur light..its guna run like crap until u do...i tryed the "relearning" thing and most of the time it works but on that it doesnt
Monday, May 02, 2011 4:22 AM
btw on mine the fan would run really hard (u could feel it standing behind the car) and it was shifting hard..i even got it to chirp first gear on my way to the parts store..lol (had a lil fun) i also have a 97 2.2 ohv sunfire
Monday, May 02, 2011 2:13 PM
i dont believe its got a mass air flow i think it just has a map sensor. but ill check that cause thats what its doin. and i cant get the computer to link so i cant check the codes or reset them
Monday, May 02, 2011 2:54 PM
robert smith wrote:and i cant get the computer to link so i cant check the codes or reset them
cigarette lighter fuse is blown.
Monday, May 02, 2011 3:27 PM
Had that problem too..lol hope u solve ur problem, im ready to drive my j off a frickin bridge
Tuesday, May 03, 2011 5:32 PM
all fuses are fine said that in my first post, daniel cooper if i figure it out ill let you know what it was
Tuesday, May 03, 2011 6:13 PM
its a 95, OBD1. unless you're scanner can read both OBD1 and OBD2 you won't be able to connect to the ECM with it.
Tuesday, May 03, 2011 7:42 PM
ok kool..just figured id share wat happend from my expierience and how i solved it
