just put my 04 back together when i turn the key everything comes on can hear fuel pick up but when i turn the key no click from the starter or anything bad ground maybe?? any ideas??
While turning the key, atempting to crank does the starter have juice from the battery?? Does it have a ground?? If you anwer those questions yes, jump the starter with a wire from the battery and see if it will start. If it does not work, replace starter, if it does, then ur ignition switch or tumbler could be bad or could be a starter relay is bad. I seen the tumbler issue on my buddies 02 LSS and it would not let the car start and cause weird other issues too. And it happened right after the engine was replaced. Goodluck.
Edited 1 time(s). Last edited Tuesday, November 30, 2010 7:30 PM
Idk what it's problem was I checked all my wires and verifying everything was fine and in order still nothing so I jumped the starter and it cranked right up and has without jumping the starter everytime since then thought it might have went out but it isn't giving me any problems now
Hmmm weird indeed. Im almost wondering if the starter needed a little push and now its fine. Well either way, keep us posted.
Been cranking just fine, still no problems with it
Brushes were probably stuck in the stater from sitting.
yeh sounds about right sat in my shop for like 5 months
