High Idle, TPS? - Maintenance and Repair Forum
High Idle, TPS?
Thursday, June 19, 2008 5:20 AM
This has been sort of an on going problem with my car. For some reason, it will just start idling high. Right now it idles about 1200 RPM. I hooked my scan tool up to it and with the engine off and with the engine running, the TPS shows 1.1%. Pushing the accelerator all the way will make it read 100%. Should that reading be 0% when I don't have my foot on the pedal?? I checked for vacuum leaks and haven't found any so far. This has happened a couple times before and at one point the car was almost undriveable because it idled so high. I'm talking around 2k+ RPMS. Any other suggestions?? IAC maybe?
Re: High Idle, TPS?
Thursday, June 19, 2008 7:39 AM
The TPS is just a potentiometer, so having a 1-2% error in the resistance is well within tolerances. In other words, 1% isn't going to make a difference.
Does your car throw any codes when it idles high?
Re: High Idle, TPS?
Thursday, June 19, 2008 8:04 AM
unhook the battery for 10 min and see if that fixes it worked for me!
2000 z24 Cavalier
Re: High Idle, TPS?
Thursday, June 19, 2008 3:03 PM
No codes and unhooking the battery worked for me before but I'd like to finally figure out and fix the underlying problem.
Re: High Idle, TPS?
Thursday, July 22, 2010 6:05 AM
i am having the same problem at the moment
my idle was high just the same and im throwing an evap emitions code and my tps was bad so i replaced it
now with the new tps on i hit the gas (wot) it just bogs down and almost dies "bla bla bla bla bla" dead
