I have a 2003 Sunfire and all of a sudden the Cruise Control quit working? What all do I need to check to hopefully get it back working?
Check the cable, make sure it didn't come disconnected anywhere or break. If it is fine, I would next make sure that the electrical plug didnt come disconnected from the cruse box.. if that is also fine, I would check to see if there is a relay/fuse that may have gone bad. If all checks out, most likely need a new cruise box.
Were you just driving down the road and it quite? Or did you do something while it was set and it turned off? Mine would cut off when I turned my right blinker on and found out it was because my right front turn signal was blown.
NaviCavi (thnkin04eco) wrote:Were you just driving down the road and it quite? Or did you do something while it was set and it turned off? Mine would cut off when I turned my right blinker on and found out it was because my right front turn signal was blown.
Happened on my brothers Cav. Changed the bulb and problem solved
Do you brake lamps work?
