recently i washed out my engine. i used some degreaser which worked pretty well, i sprayed it on then rubbed it in a little then hosed off the engine. now my oil pressure gauge doesn't work. i thought it was the wiring because i looked at the ground connection and the wiring was somewhat black so i replaced that and nothing changed. the end top of my pressure sender popped off, but it still worked. i think water may have gotten into that top somehow even though i electrical taped it back on. anyways, my oil pressure gauge reads full now and i think i need a new one. also my underbody led's are not as bright as they used to be, and my car hesitates when it comes to a stop. please help?
1st issue on hand.. electrical tape. in an open area.
yeah
this thread is no longer relevant. my underglows have their shine back but my oil psi gauge i got replaced so all is well again. but yeah i know that was just a temporary solution.
jschristian44 wrote:recently i washed out my engine. i used some degreaser which worked pretty well, i sprayed it on then rubbed it in a little then hosed off the engine. now my oil pressure gauge doesn't work. i thought it was the wiring because i looked at the ground connection and the wiring was somewhat black so i replaced that and nothing changed. the end top of my pressure sender popped off, but it still worked. i think water may have gotten into that top somehow even though i electrical taped it back on. anyways, my oil pressure gauge reads full now and i think i need a new one. also my underbody led's are not as bright as they used to be, and my car hesitates when it comes to a stop. please help?
Why the @!#$ do you keep coming here asking @!#$ if your just going to go and take care of it before anyone replies anyways? If your actually going to ask for advise then post if your going to tell us about all your gay ass mods that you broke and are replacing keep that to your self. K thanks now go burn your car to the ground along with your computer.
Disclaimer:
Dey see me Trollin' Dey hatin' for trollin dey trying to catch me ridin dirty.
Im gonna smack your mother for not swallowing.
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
i learned something from this thread, thanks justin
