Sunfire Conv Window Regulator -- Where to buy? - Maintenance and Repair Forum
Wednesday, April 14, 2010 9:37 PM
As the title says I'm trying to find these regulators and everything I find says "2 door, except conv"
Any help as to where I can get these?
Re: Sunfire Conv Window Regulator -- Where to buy?
Thursday, April 15, 2010 8:01 AM
These are very hard to find right now. Try yards.
Others may have better location info. But theyre rare.
Thursday, April 15, 2010 9:07 AM
GM Parts Direct: www.gmpartsdirect.com
(Cant do direct link but you will find it under GMPD > [I just entered 1998] Sunfire > Door > Glass & hardware> Regulator > Electric/Manual)
Electric Right - Convertible - Convertible
95-00 $544.22 $282.99
Electric Left - Convertible - Convertible
Manual Right - Convertible - Convertible
95-00 $166.40 $98.64
Edited 2 time(s). Last edited Thursday, April 15, 2010 9:10 AM
Thursday, April 15, 2010 3:25 PM
Do I need the 3rd one, the one thats listed as "manual" if my windows are power?
I totally forgot about gmpd, good call
Friday, April 16, 2010 3:21 PM
No, you don't need the manual one. I have to ask, why do you need the whole regulator? Unless the regulator itself is bent or broken, you can re-use it and just replace the motor for way less money. (All the motors are the same and are common aftermarket parts.) The motors are riveted to the regulators too, and you have to isolate the glass-counterbalance spring before you remove the motor, but it can be done for much less than replacing the whole regulator assembly. The only caveat to this is that many aftermarket motors are more powerful than the OEM ones (no surprise there). While this doesn't matter to the coupes and sedans as they have full window frames to stop the glass on the up-stroke, it makes a difference on the convertibles because the up-stops are not very robust and the constant pounding of the stronger motors will bend the stops. Just be aware. I replaced a regulator with a new OEM one, but will only do the motors in the future.
Just so you know, the convertible regulators differ only from the coupe in that the main crank arm has a few more teeth. This gives a little more travel in the regulator as the convertible window glass is slightly taller than the coupe. Also, I guarantee you that when you get the door apart, you'll find the two plastic clips that guide the leading edge of the glass in the forward glass run channel, broken and laying in the bottom of the door. These clips are discontinued. In order to keep the glass from rattling itself to death, I installed a length of felt coated rubber glass run weatherstrip in the forward glass run channel. (I got it from JC Whitney.) It's not a perfect solution, but it does work. (I can provide more details if needed.)
(Note: These comments are for 3rd Gen 'verts.)
markc50...formerly 1of7627 but that login doesn't work anymore.
Tuesday, April 20, 2010 10:11 AM
I used a power regulator in my Vert and have never had an issue. I drilled out the rivets and used short bolts, lock washers and nuts.
99 GT Convertible Black on Black / Z24 Seats / 17" MR7s 235/45 Potenza G009s / K&N
Thursday, April 22, 2010 5:27 AM
i would try your local junkie they generally have one or 2 lying around
