so i have an 2003 cavalier 2.2 auto and the upper motor mount is bad. the motor is moving around alot in reverse and 1st gear bad and the rest i can feel it but its not that bad. i went to a parts store but could not find anything close to it. and i was wondering if any one knows were to get one, how much?
turbo tech racing site sponcer sells them also level zero motorsports
is it worth trying to find a factory one or just get an aftermarket one?
I've gotten a replacement stock one from rockauto.com, it requires you to drill some holes in the bottom of the original mount to install it though... because it's an "insert" instead of an entire replacement mount.
david raines wrote:so i have an 2003 cavalier 2.2 auto and the upper motor mount is bad. the motor is moving around alot in reverse and 1st gear bad and the rest i can feel it but its not that bad. i went to a parts store but could not find anything close to it. and i was wondering if any one knows were to get one, how much?
Check out www.TurboTechRacing.com We have got you covered, no more sloppy mounts here
-Aaron
Richard K wrote:I've gotten a replacement stock one from rockauto.com, it requires you to drill some holes in the bottom of the original mount to install it though... because it's an "insert" instead of an entire replacement mount.
i just put a prothane insert in mine and i didn't have to take apart the cage.... although the ENTIRE factory was MISSING. GONE. so it's a good thing i changed it.
