All these light come on as soon as i shift out off park. Sometimes the car will kinda sputter or jump and the low trac light will come on. This morning ilow trac came on and i turned the wheel and it died. Im not sure if these are all related but they all happen at the same time
Haha my car is doing the same thing lol. I just cleaned out the plugs for my abs sensors and reconnect them, Seems to have worked so far.
^^^ how long has it lasted so far? what did you use to clean them? do you have to remove the wheels?
Yes you have to remove the wheels. There's a fine toothed ring in front of a rubber boot just behind the wheel bearing. It's probably covered in gunk, use brake cleaner. And then the actual sensor probably has metal shavings stuck to it. Blow it off with compressed air, cover your eyes when doing this part.
