Well I got the nut side off no problem.
But when I went to get the quick release off.. the plastic piece that you squeeze to open it is gone.
What do I do?
<img src="http://www.majhost.com/gallery/HCAJosh/crap/shooshined.jpg">
- putting the pieces back together -
you use the search button its got the answers
cut the darn hose and water clamp the new fliter on! Works wonders past the quick release(actually quicker to turn a screw driver) and yes, do some searching...
98z24, lowered 2", aem intake, cat-back striaght pipes!, cop ligths in the front and rear, 18" liquid metal's, primer black, tint, full audio and video.
the factory line doesn't have the part you sqeeze. You have to go to a auto parts store and get a fuel line disconnect tool for gm and slide it in to unlock the clips in the factory hard line.
is the clip on the factory hard line black? i know the one on my new fram filter is white, but i read about green ones too, do i def need a tool to disconnect this black clip of the line? or is there a simple way that i cannot see?
The OEM filter has a metal clip. I bent the crap out of it when I replaced mine but the replacement filters have the plastic clip, which works much better. It's frustrating, but doable. Just don't be retarded and start cutting lines.
2.2 97 Cavalier......the "Crapalier"
